Create error report containing failed tester attributes
  • June 19, 2018
  • 13 views
I am carrying out data quality tests and I would like the results of failed tests in an excel doc. I would normally use the AttributeValidator and the _fme_validation_message but I need to use testers.
An example of one test: if the 'type' = individual then the 'industry sector' should be null. So in the table below, I would want to see the last line in an error report
TypeIndustry sectorindividualcompanyagriculturecompanyconstructionindividualretail
Any suggestions welcome.
danilo_fme
Forum|alt.badge.img+52
  • June 22, 2018
Hi @cam
I created a simple Workspace with the Excel file like Source.
The transformer Tester was used to filter the Individual value:
The transformer AttributeCreator was used to set Null value for Industry sector when the Type = individual:
Results in FME Data Inspector:
Thanks,
Danilo
jneujens
  • June 22, 2018
Can't you just connect an excel writer to all the failed ports of the testers?
