Pivot / transpose data in multiple columns into single column to write to a txt file
  • August 3, 2016
  • 63 views
Hi there,
I have a table with two columns:
HEADERDATAHEADERDATA
I need to write the information to a txt file which needs to be formatted as:
The headers are all unique.
Any solution is fine - however would appreciate as much information as possible, esp if using Python.
Thanks,
Heather
Best answer by ebygomm
Create an attribute which contains both sets of data separated by a comma, split into a list then explode the list
Forum|alt.badge.img+46
  • August 3, 2016
  • August 3, 2016
Hi @heatha_featha, another thought. You can use the Cloner to create two copies for each record and assign the HEADER and DATA value to a single attribute (text_line_data) according to the copy number (0 or 1), so that they will be written into a text file alternately.
Thanks @egomm and @takashi both solutions work great :)
