DWG Writer - Force Output to Autocad Line
hansgm
Forum|alt.badge.img+5
Hello
I want to write Lines (with 2 points) instead of Polylines, so i use a Chopper to create Lines with 2 Points. But if i use a DWGStyler to set the Linetype all those Lines are written to DWG as Polylines. If i do not use the DWG Styler everything is like i need it. I'm not sure if the DWGStyler is the main reason for this.
So i would like to know, is it possible to force the Writer to create Autocad Lines instead of Polylines?
The writers Autodesk AutoCAD DWG/DXF and Autodesk AutoCAD RealDWG DWG/DXF create the same result.
Thanks
Best answer by daveatsafe
Hi @hansgm,
The DWGStyler adds (but does not expose) the attribute autocad_elevation, which forces the writer to create a polyline. Please use an AttributeExposer to expose autocad_elevation, then an AttributeRemover to remove it.
daveatsafe
Forum|alt.badge.img+19
  • July 20, 2020
Hi @hansgm,
hansgm
  • July 20, 2020
Hi Dave
that's it.
Thanks very much.
Hans
