Can anyone tell me how to colour the values of height data supplied by the Ordnance Survey in the Terrain 50 data in ASC format.
I want to create a gradual increase in colour dependant on the height value in the ASC file.
Thanks
Andy
Depening on speed of colour increase u can use linear, cubic etc. algorithms.
U also need to normalize them ( for instance fme_c0lor is between 0 and 1 float)
Here is an example:
The GS_Function attribute holds the output for a algorithm. I create a couple algorithms and put them in a userchoicelist. R,G,B are also parameter, so u can use the wheel to choose a startingcolor.
I use a RasterBandInterpretationCoercer to coerce it to UNIT8, scaling by by data values, use the AttributeCreator to create a palette and then The RasterPaletteAdder to add the palette to the raster, then the RasterPaletteResolver to turn it into an RGB raster
The palette i use for elevation is below. The zero value entry is a special case I use for NoData
