Looping through Feature class columns to replace values
  • May 21, 2020
  • 61 views
johnehlen
Hello All,
I am trying to loop through a feature class with 30+ fields, each field having terrible quality data filled with duplicate white space.
I am trying to find a way to loop through the feature class, checking each field and then replacing the duplicate white space with single white space. I can do this manually, one at a time, with 30+ StringSearchers->StringReplacers. However, I am wondering if anyone has found a way to build a custom function to loop through each field and replace values? I would prefer to call a custom transformer and loop through all fields than build 30+ groups of two transformers. Currently in the string replacer I only see the option to do one string at a time.
Best answer by johnehlen
Never mind, I would delete this question if I could.
String replacer with replace regex expression.
johnehlen
  • May 21, 2020
