Best Answer
Startup Python Script - How to make python input() work?
  • January 8, 2018
  • 5 replies
  • 92 views
robertr
Hello,
I was initially running a python script outside FME to prompt a user for a said city to download data for.
I would like to integrate that script as a "Python Startup Script", in FME 2017.1.
I am stuck right at the beginning where I want the user to mention the city but the input caller stops the progress of the translation and the console log is waiting for something I am not sure how to enter. It would be even cooler if I could present him a dropdown list to chose from.
county_name = input('City Name: ').title()
The log window shows the following:
FME_BEGIN_PYTHON: evaluating python script from string...
Enter the City Name:
...aaand I cannot do anything here. Or I am not aware of the input place.
Any advice on how to overcome this?
Best answer by mark_f
Hi - you need to use a Published Parameter - create one in the navigator panel. Then at runtime you can supply a value. Fetch this value into the startup script using
value = FME_MacroValues['MYCITY']
or
import fme
value = fme.macroValues['MYCITY']
where MYCITY is the name of the parameter created.
So you can create a Published Parameter as free text entry, but also create picklist and any other types of parameters.
  • January 8, 2018
or
import fme
robertr
  • January 8, 2018
or
import fme
uuuhhh... I seeeee. Thanks @mark_1spatial!
There is huge potential in mastering this part. I will start looking in more depth into published and private parameters + link-ing them to this or that.
Do you happen to know a place where all these Python related features from FME are located? Here I mean all the stuff that comes when importing FME in python (like FME_MacroValues)
Is there anything else that you found helpful except this page: linktoDocumentation?
  • January 8, 2018
or
import fme
Some good examples here:
https://knowledge.safe.com/articles/706/python-and-fme-basics.html
there is online help included for Python also. There are a number of members on this forum who are FME Python Jedi ;)
robertr
  • January 8, 2018
Good to hear!
One more question. I noticed that $MYCITY remains set to the option I selected in the 1st place.
When reopening the workspace, it does not prompt anymore although I did not select anything for "default" value. I always want it to prompt.
Laster Edit: convert to private and select "Prompt Before Running Workspace".
  • January 9, 2018
or
import fme
Unfortunately that’s not possible and something that bugs me too! I raised this idea asking for this to be changed so feel free to go and vote for it at this link ;)r
https://knowledge.safe.com/idea/45682/published-parameter-no-default-value.html
