My problem is quite close to the one with the roof-models. But I want to get the whole building as a solid because I'm interested in it's volume.
I have a TIN for the ground and a TIN for the roof. For the walls I can extrude the polygon to a solid. Is it possible to cut back the solid to the two surfaces?
Or do I have a chance to get the volume between the two surfaces for each polygon without physically building up the model? As a result I need to add the volume as an attribute to a polyline, polygon or solid to identify to which building it refers.
Right now I only have access to 2014 Version
