I have about 60000 points and 25000 polygons going into a pointonareaoverlayer. The overlayer works fine and the points are picking up the attributes from the polygons.
But, duplicates of the points are being created in the output. 3 or 4 duplicates are created for each point with the exact same attribute data - so I'm getting over 200000 points on output. I know I can use duplicate remover to get rid of them, but these duplicates shouldn't be created in the first place.
Any ideas on why this would be happening and how to fix it?
