count number of points in a polygon
  • June 29, 2017
  • 295 views
thedeeleys04
Hi there,
I'm using a PointOnAreaOverlayer to try and count the number of features ("UPRN") in a polygon ("DMA"). However, its not working. What group by or parameters might I need to set?
Best answer by erik_jan
If the count in the transformer is not working properly, the cause is quite often that the sources (points and polygons) are in different coordinate systems. Can you verify that both sources are in the same coordinate system? If not, use the Reprojector transformer to get them in the same coordinate system, before feeding the to the PontonAreaOverlayer.
erik_jan
Forum|alt.badge.img+26
  • June 29, 2017
You do not need a group by parameter. The number of points in a polygon should be added as an attribute (default _overlaps) to the area output features.
erik_jan
  • June 29, 2017
thedeeleys04
  • June 30, 2017
Hi erik_jan
That did the trick - I added the Reprojector transformers and now I'm getting a count. Thanks for your help!
