Creating a new Line dataset
  • February 22, 2018
  • 6 views
I am using an existing polygon buffered dataset along with another line dataset to produce a new line dataset, where the source lines either contain or intersect the source polygon. The problem I am facing is that there are considerate gaps between the lines of the new dataset as the sources are either not fully contained in the polygon or don't intersect at a specific point.
Using GIS software I can trace to join the lines, how can I automate this in FME?
Forum|alt.badge.img+49
You could try the Snapper to solve the gaps in the lines.
