Split a range address in multiple list addresses
  • September 12, 2016
  • 6 replies
  • 84 views
rudy_v
I want to split an address which are in range (from-to) example 12-24 Collins Street, into separate
attributes:
12 Collins Street
14 Collins Street
16 Collins Street
18 Collins Street
20 Collins Street
22 Collins Street
24 Collins Street
I thought of doing it with a pythoncaller, but could get it to work well
Any suggestions
Best answer by rudy_v
All of the above solutions above worked for me. Great work all of you.
We use this kind of address splitting and matching all the time. Previously i did the splitting in Access with code and later in SQL, but it is much easier in FME running on server
I will use this in my GeoCoding service, probably build a custom transformer
I would like to accept all 3, but it seems you can only have 1
Rudy
Forum|alt.badge.img+5
I believe this can be done without resorting to Python. I've had a quick look at it and I think I have a possible solution using AttributeSplitters and a Cloner. It works for the example you provided. I've attached an example workspace. Let me know if this is what you were looking for!
itay
Forum|alt.badge.img+18
I agree with @kim, python is not necessary, but probably can provide a solution.
I have attached my take on it, which is 100% FME....
Hope this helps,createadressrange.fmw
Forum|alt.badge.img+7
Hi @rudy_v,
This question can indeed be solved using Python but there is also a pure FME option. My suggestion can be found below. If you would like to use Python anyway, just let us know and we will help you with that!
The used method in the workspace below is calculating the range, the number of addresses to add, afterwards you clone the feature and update the address field.
Good luck!
workspace-addressranges.fmw
itay
Workspace
rudy_v
Rudy
mark2atsafe
Forum|alt.badge.img+59
  • September 13, 2016
Rudy
True - there can be only one! So I accepted your answer. I'll just mention that there is a geocoder transformer in 2017 now, that connects to a whole bunch of different services. You'll still need the address splitting you asked about, but perhaps it will help with the following geocoding.
