How to write attribute based on the contents of a wkt field?
  • July 24, 2014
  • 31 views
I have an attribute in my xml reader which contains WKT geometries. I would like to either split the writer according the whether the geometry is point, line, polyline,or polygon, or test whether the field contains these words and write  "point", "line", "polyline",or "polygon" to another attribute in the writer.
Which transformers would do the best job?
  • July 25, 2014
If you have created geometries based on WKT, you can branch the data flow into Point, Line and Area with the GeometryFilter. And then, the Tester can be used to branch the Line features into line and polyline (@NumCoords() = 2 or not).
Takashi
