Create a report from features
  • October 3, 2019
  • 105 views
dms2
Forum|alt.badge.img+11
What transformers do I need to generate a report from a number or features like these?
LAYERVALUECHECK_CLASSATTRIBUTEVALUEID1ID2SitesOut of domainSite_typeHistorical45SS023SitesOut of domainSite_typeNature cons60SS017Info_pointsOut of domainFacilityMMC22IP06Info_pointsNot a numberNum_visitsAbout 1015IP08StopsToo longVisibilityNot so good25ST041SitesOt of domainSite_typeHistorical31SS001SitesToo longIn_siteEmma (except Mondays)21SS015SitesOut of domainCertificCHECK62SS030
I need to generate a tree report showing for every LAYER every different VALUECHECK_CLASS, and for every VALUECHECK_CLASS every different ATTRIBUTE. And then show a table or anything similar with VALUES checked and the feature IDs (sorted if possible).
Something like this:
Sites
1. Out of domain
  • Site_type
ValuesGlobal IdLayer IdHistorical31
45SS001
SS023Natural cons60ss017
  • Values Global Id Layer Id
ValuesGlobal IdLayer IdCHECK
62
SS030
2. Too long
  • In_site
ValuesGlobal IdLayer IdEmma (except Mondays)21SS015
Info_points
1. Out of domain
  • Facility
ValuesGlobal IdLayer IdMMC22IP06
2. Not a number
  • Num_visits
ValuesGlobal IdLayer IdAbout 1015IP08
I thought the Aggregator transformer together with the HTMLReportGenerator transformer would help but I can't get at all what I want. Any ideas?
Best answer by dms2
After taking a break to clear my mind I found a solution.
I used a series of Aggregators to create nested lists. So the first Aggregator generates an Id list with ID2 and ID1 attribute values, the second Aggregator generates a list with VALUE attribute values and ID list values, and so on.
I end up having a feature for each LAYER value and each feature has nested lists like this:
Class{}.VALUECHECK_CLASS
Class{}.Attribute{}.ATTRIBUTE
Class{}.Attribute{}.Value{}.VALUE
Class{}.Attribute{}.Value{}.Id{}.ID1
Class{}.Attribute{}.Value{}.Id{}.ID2
Afterwards I used PythonCaller transformer to loop through each nested list starting with Class list to generate a tree report.
I used nested While loops to loop through list indexes:
        layer= feature.getAttribute('LAYER')
        classList = feature.getAttribute('Class{}.VALUECHECK_CLASS')
        l_classList  = len(classList)
        i = 0
        while i < l_classList :
           attrsList = feature.getAttribute('Class{'+str(i)+'}.Attribute{}.ATTRIBUTE')
            l_attrsList  = len(attrsList)
            j = 0
            while j < l_attrsList :
                valuesList = feature.getAttribute('Class{'+str(i)+'}.Attribute{'+str(j)+'}.Value{}.VALUE')
                l_valuesList  = len(valuesList)
                k = 0
                while k < l_valuesList :
                    idsList = feature.getAttribute('Class{'+str(i)+'}.Attribute{'+str(j)+'}.Value{'+str(k)+'}.Id{}.ID1')
                    l_idsList = len(idsList)
                    l = 0
                    while l < l_idsList:
                        l += 1
                    k += 1
                j += 1
            i += 1
danilo_fme
Forum|alt.badge.img+52
  • October 4, 2019
Hi @dms2
I used the transformer TestFilter to filter the fisrt condition:
Thanks in Advance,
Danilo
dms2
  • October 7, 2019
        i = 0
            j = 0
                k = 0
                    l = 0
                        l += 1
                    k += 1
                j += 1
            i += 1
dms2
  • October 7, 2019
Hi @dms2
Thanks in Advance,
Danilo
Thanks! I got it. See my answer above.
