To assign the spatial order, an attribute numeric integer field will be added in the writer feature type called listing and it would be populated beginning with "1" for the 1st parcel intersected by the beginning point of that line. Then the next parcel intersected by the line would have a listing attribute number of '2', and so on until the last intersected parcel at the end point of the line is reached.
Any suggestions?
