Is it possible to update a geometry to NULL with a geodatabase writer?
  • February 24, 2016
  • 7 replies
  • 127 views
I am updating attributes for esri geodatabase feature classes which also participate in relationship classes. The attributes, including the geometry can change to NULL. How can I realize this? @RobynAtSafe, any idea?
Best answer by fmelizard
Hi David - As of FME 2014 handling NULL attributes and geometry was fully integrated into the product - see https://knowledge.safe.com/articles/21423/how-does... - for all the details.
So updating as NULLs should not be a problem. To eliminate features which contain NULLs, you can use Testers, GeometryFilters, AttributeFilters, or the NullAttributeReplacer to identify features with NULL values. I am not sure how Esri will handle a feature in a relationship class with a NULL geometry
If I have misunderstood your question please send your workspace, sample data and logfiles to us in support and I will take a closer look. https://support.safe.com/knowledgeSubmitCase
Cheers,
Robyn
mark2atsafe
Forum|alt.badge.img+59
  • February 24, 2016
Maybe the GeometryRemover transformer?
fmelizard
Forum|alt.badge.img+21
  • February 24, 2016
Cheers,
Robyn
Cheers,
Robyn
Thanks for your quick response and sorry for my late response (I'll check my notification settings). I do not need to eliminate entire features with null geometries. Rather, I need to delete the geometry attribute of existing features. I do not want to delete the entire feature. I just need to erase the geometry of an already existing geodatabase feature. Hopefully the attached workspace clarifies what I am trying to do. updategeometry2null.fmw
mark2atsafe
If your example workspace produces the correct result, simply add the GeometryRemover in place of the null-creating Creator. That will set the geometry to null.
Mark, the workspace does not produce the correct result: the original geometry does not get updated to NULL, i.e. the original polygon stays in place whereas the timestamp confirms an update has been commited . Adding a GeometryRemover is not helping out either. Alternatively, I have tried the FILEGDB writer but no luck either.
mark2atsafe
I've talked with my colleagues in the support team and we wonder if it might be a problem in FME that needs fixing. I don't see any other reason why it wouldn't be possible to reset the geometry to null. I'm having them look into the issue further and we'll get back to you. If you want to file this as a case with out support team it would ensure it doesn't get lost in the mix, as it might do if we just leave the discussion on here.
steveatsafe
Forum|alt.badge.img+13
  • September 7, 2017
This is being looked at from FME 2018. Stay tuned.
