FME 2019 work bench crashes on start-up
Hi
In my windows 2016 data center sever, installed FME Desktop 2019 (Build 19246-win 64) edition. It connected to another flexnet floating license server [FlexNet Licensing (v11.16.2.1 build 245043 x64_n6)] which has valid licenses . I can do nslookup of license server with aliasm works good.
On opening FME work bench, it crashes immediately (screen disappears without any message) on loading transfer stage. This is brand new installation.
Any clues. Checked all .dat files,but could not find cause for this behaviour.
itay
Forum|alt.badge.img+17
  • October 1, 2019
Try the chat on https://www.safe.com/ otherwise I would suggest support at:https://www.safe.com/support/
  • October 2, 2019
You should also make sure to try running FME once with local administrator privileges, just to rule out any permission issues.
This works good in windows 10 (laptop), only issue is on Server class machine,. No permission issues since am admin on the server.
New Build worked .
FME Desktop 2019.1.2 for Windows
mark2atsafe
Forum|alt.badge.img+44
  • October 2, 2019
lakshgisprog wrote:
New Build worked .
I'm not sure what the problem was - and I see nothing in the changelogs - but I'm glad it's working now.
