Can I use String replacer to add a character between two regular expessions?
  • March 2, 2017
  • 29 views
Hello,
I need to reformat some strings.
3/2-A1 needs to become 3/2-A01. Where I have a dash followed by a letter followed by a number I want to replace it by dash, the same letter, 0, then the same number.
I can find my string using a regular expression :
-[A-Z][1-9]
and I've tried -[A-Z]0[1-9] in the Replacement text box of String Replacer but (unsurprisingly that just gives me
3/2-[A-Z]0[1-9]
Is there away to search for the whole regex, but only replace part of it?
jdh
Forum|alt.badge.img+40
  • March 2, 2017
text to match: (-[A-Z])([1-9])
replacement text: \\10\\2
putting parentheses around sections creates parts, and then you can refer to the parts as \\1, \\2 etc.
