Using stringreplacer with conditional values and regular expressions
fmenco
Forum|alt.badge.img+5
Hi, I have an address dataset with the usual errors like abbreviated streetnames (str instead of street, ln instead of lanes, bd instead of boulevard) etc.
I want these written out, and by using regular expressions with individual stringreplacers I can get this to work.
However, I want just one stringreplacer to do the job. When I try this, I get empty values for the streetname attribute, so I think my parameters must not be filled in correctly, or I messed up the syntax on the regular expressions maybe.
Where do I set my conditions? In the "Text to replace" field, or in the "replacement text" field?
Right now, one of my conditions is:
test condition:
IF: @Value(street) CONTAINS_REGEX str$
Output Value:
street
I've tried numerous ways, using reg expresions as output value, or using string functions, none worked.
Can I get a clear example from someone?
  • March 7, 2018
I just tested with a feature containing an attribute "street" with the value "Bleaker str" and the following Tester:
Seems to work as expected in FME 2017.1.2.
Could you perhaps post a minimal working example workspace that demonstrates the issue?
gio
Forum|alt.badge.img+15
  • March 7, 2018
@fmenco
in the stringreplacer "use regexp" = yes
string to search
(.)str$
replacement
\\1 street
explanation:
the (.) captures anything in front of str
\\1 places the first capture group (in this case there is only one)
fmenco
  • March 7, 2018
gio wrote:
@fmenco
string to search
(.)str$
replacement
\\1 street
explanation:
I tried this, and it didn't work. I still get empty values for my street name attribute. I tried it with conditional values. I tried changing str, bd, ln etc through different conditional values and that just seems to erase the values.
A string replacer for each scenario does work, but then I end up with about 9 stringreplacers after each other in one work bench.
Forum|alt.badge.img+19
  • March 8, 2018
Hi @fmenco, if the abbreviated words could appear only at the end of an address string, this would be a possible way.
Regular Expression:
(?<=\s)(str|ln|bd)$
StringReplacer Parameters:
However, it's not good at maintainability and extensibility. If you are familiar with a scripting language such as Python, Tcl, or JavaScript, I think it would be better to consider writing a script in this case.
gio
  • March 8, 2018
gio wrote:
@fmenco
string to search
(.)str$
replacement
\\1 street
explanation:
i use fme 2016 and it does work.
and (.)(?:str|bd|ln|blvd) etc.
(?:) is non capturing.
