SQL To Execute After Translation syntax problems
  • April 29, 2013
  • 9 replies
  • 55 views
Hi all,
I'm trying to run a SQL statement after a translation to execute a stored procedure.
This SQL executes correctly -> EXECUTE EDIGISDB.data_extracts.log_data_extract ('FLUOR') in SQL*Plus however it's erroring in FME with the following message.
2013-04-29 15:29:35| 1.0| 0.0|ERROR |BADNEWS: Execution of statement `EXECUTE EDIGISDB.data_extracts.log_data_extract ('FLUOR')' did not succeed; error was `ORA-00900: invalid SQL statement
Any and all assistance is greatly appreciated. We've been trying different syntax none of which seems to work.
Thanks
Micahel Drover
  • April 29, 2013
try this syntax:
begin
EDIGISDB.data_extracts.log_data_extract ('FLUOR');
end;
You will probably get some warning in the log about the semicolons, but you can ignore those.
David
  • April 29, 2013
Would using
FME_SQL_DELIMITER ;
on the first line not remove the warnings?
  • April 29, 2013
Hi Mark,
yes, in this case it would replace the warnings with errors, since FME would then execute each part separated by a semicolon separately, which would confuse Oracle a lot :-)
On the other hand, perhaps it could be worthwhile to also try without the begin/end transaction clause. If it works, no semicolons would be needed at all.
David
sam
Participant
  • Participant
  • April 30, 2013
I had followed similar approach what david has suggested. It works fine
sam
  • April 30, 2013
Thanks for the replies guys but stil no success with this.
I've tried David R's suggestion of removing the ; and begin/end component and still no joy. I've also tries the follwoing
FME_SQL_DELIMITER ;
begin
end;
With the same result...man this isstating to test me!
Thanks
Michael
  • April 30, 2013
first of all, do not use "FME_SQL_DELIMITER" at all, it is not applicable in this scenario.
Did you try my original suggestion with the begin/end clause? It should work.
If it doesn't, is the error message still the same? Can you post your log file somewhere?
David
  • April 30, 2013
Hi David.
I did try your initial suggestion as well as including the DELIMETER statement.
|t the moment I;m not having success with
begin
end;
The part error log I'm getting is below.
2013-05-01 07:58:15| 0.9| 0.0|WARN |Semicolons detected in SQL. May need to use FME_SQL_DELIMITER keyword to specify a delimiter. SQL is: 'begin EDIGISDB.data_extracts.log_data_extract ('FLUOR'); end;'
2013-05-01 07:58:15| 0.9| 0.0|ERROR |BADNEWS: Execution of statement `begin EDIGISDB.data_extracts.log_data_extract ('FLUOR'); end;' did not succeed; error was `ORA-06550: line 1, column 7:
PLS-00201: identifier 'EDIGISDB.DATA_EXTRACTS' must be declared
PL/SQL: Statement ignored
'. (serverType=`ORACLE8i', serverName=`gisprod', userName=`miread', password=`***', dbname=`') (.\\stfdb.cpp:245)
2013-05-01 07:58:16| 0.9| 0.0|WARN |Semicolons detected in SQL. May need to use FME_SQL_DELIMITER keyword to specify a delimiter. SQL is: 'begin EDIGISDB.data_extracts.log_data_extract ('FLUOR'); end;'
2013-05-01 07:58:16| 0.9| 0.0|ERROR |BADNEWS: Execution of statement `begin EDIGISDB.data_extracts.log_data_extract ('FLUOR'); end;' did not succeed; error was `ORA-06550: line 1, column 7:
2013-05-01 07:58:16| 0.9| 0.0|INFORM|Translation was SUCCESSFUL with 4 warning(s) (0 feature(s)/0 coordinate(s) output)
2013-05-01 07:58:16| 0.9| 0.0|INFORM|FME Session Duration: 21.8 seconds. (CPU: 0.2s user, 0.3s system)
2013-05-01 07:58:16| 0.9| 0.0|INFORM|END - ProcessID: 6376, peak process memory usage: 33960 kB, current process memory usage: 33660 kB.
Translation SUCCEEDED.
When refreshing the linked table in Mapinfo I'm not seeing the update that I'm expecting.
Appreciate your help David.
Thanks
Michael
sam
Participant
  • Participant
  • May 1, 2013
Hi
The error which you have reported is actually generated from Oracle and not from FME. FME has infact executed the stored procedure
Please test your stored procedure
ORA-06550 is generally PLSQL compilation error
Sam
  • May 2, 2013
Thanks David R. Your syntax was correct however there were some access privileges that needed to be allowed for our read user. I've had our Oracle guru take a look at it for me and he has sorted it. The
 was the giveaway for him.
It's all up and running.
Thanks again.
Michael
