Why the PythonCall local polyconic reproject on LL27 gives incorrect results, but WGS84 give correct ones
  • March 1, 2013
  • 26 views
aguan
Forum|alt.badge.img+11
I have a pythoncaller that does a local polyconic reprojection. The orgin point  is (sur_long, sur_lat,z) = (-87.9960175,28.6407318,0.0) and the point to be reprojected to (lat,long,z)  is (xoffset,yoffset,zoffset) = (0.0,0.0,0.0).  Here is the pythoncaller code:
class myPythonFactory(object):
    def __init__(self):
        self.count_features = 0
        self.logger = pyfme.FMELogfile()
    def input(self,feature):
        uwi = str(feature.getAttribute('WELL_ID'))
        surf_lat = float(feature.getAttribute('SURF_LAT'))
        surf_long = float(feature.getAttribute('SURF_LONG'))
        x_offset = float(feature.getAttribute('XOFFSET'))
        y_offset = float(feature.getAttribute('YOFFSET'))
        z_depth = float(feature.getAttribute('TVD'))
        #myCSMan = pyfme.FMECoordSysManager() defined in startup python
        fmeParams['PARM1'] = str(surf_long)
        fmeParams['ORG_LAT'] = str(surf_lat)
        myfmeCS = myCSMan.defineCoordSys(fmeParams, "myfmeCS")
        pointF = pyfme.FMEFeature()
        pointF.resetCoords()
        pointF.setDimension(3)
        pointF.addCoordinates([x_offset], [y_offset], [z_depth])
        pointF.setGeometryType(pyfme.FME_GEOM_POINT)
        pointF.performFunction("@Reproject(" + myfmeCS + ",LL27)")
        myCoords = pointF.getCoordinates()
        ll = myCoords[0]
        long = float(ll[0])
        lat = float(ll[1])
        z = float(ll[2])
        self.logger.log("surf_lat = " + str(surf_lat) + " surf_long = " + str(surf_long) +
                      " x_offset = " + str(x_offset) + " y_offset = " + str(y_offset) +
                      " z_depth = " + str(z_depth) + " lat = " + str(lat) +
                      " long = " + str(long) + " z = " + str(z))
        #set lat/long
        feature.setAttribute('LATITUDE',str(lat))
        feature.setAttribute('LONGITUDE',str(long))
        #self.logger.log('Processing uwi: ' + uwi)
        self.pyoutput(feature)
    def close(self):
        self.logger.log('Total features processed: ' + str(self.count_features))
I would expect for this point, the result (long,lat) would be equal to (surf_long,surf_lat). But it is not. The results is
surf_lat = 28.6407318 surf_long = -87.9960175 x_offset = 0.0 y_offset = 0.0 z_depth = 0.0 lat = 28.6404917546 long = -87.9960290212 z = 0.0
 which is about 180 feett off what it should be. I also tried LL27-48 et al, the results are the same as LL27.
However, if I change LL27 to LL-WGS84, the resulting (long,lat) will be the exactly the same as (surf_long,surf_lat):
surf_lat = 28.6407318 surf_long = -87.9960175 x_offset = 0.0 y_offset = 0.0 z_depth = 0.0 lat = 28.6407318 long = -87.9960175 z = 0.0.
What I need to do to make LL27 reprojection correct?
Allen Guan
Nexen USA
aguan
  • March 1, 2013
BTW, here are the actual results running with LL27. Look like a complex process which involved a shift:
FME Configuration: Using FME Reprojection Engine
Reprojector: Using datum conversion type `Wgs84ToNad83' when reprojecting from myfmeCS0 to LL27
Reprojector: Using datum conversion type `Nad83ToNad27' when reprojecting from myfmeCS0 to LL27
Reprojector:`Nad83ToNad27' will use the following grid shift files:
Reprojector: .\\GridData\\Canada\\ntv2_0.gsb,,,0.5
Reprojector: NADCON grid shift files for the US and its territories
Reprojector: The following fallback datum will be used `NAD27-48'
aguan
  • March 1, 2013
I did more tests: if I transform the source (surf_long,surf_lat)  from LL27 to LL-WGS84 before it goes into the PythonCall reprojection, and then after the Pythoncaller reprojection, transform it back to LL27. The results are very close to to original (long,lat). I am happy with the results, but I wish I don't need to use these two extra AttributeReprojectors.
Allen Guan
Nexen USA
