How to turn off records
  • October 17, 2017
  • 30 views
dbklingdom
Forum|alt.badge.img+7
I have the error: The below feature caused the translation to be terminated Storing feature(s) to FME feature store file `P:\\WELL_DATA_EXCHANGE\\PGISF_WDERPRT_JS\\log\\WellDataExchange_PopulateReport_log.ffs'
I used a recorder in a TEST script now this error is showing up in all my FME scripts
fmelizard
Forum|alt.badge.img+21
  • October 18, 2017
Can you supply a screenshot of the workspace or complete log file?
nielsgerrits
Forum|alt.badge.img+64
If a Writer can't write certain features, Workbench saves these features in the same directory where the Workspace is located, the format is ffs. The same behaviour as the logfile. You can use this ffs file to analyze the not written features.
The ffs you get is probably data what could not be written. Related to input, not to the use of a Recorder.
You can reproduce this by writing a point feature to a polygon featureclass in gdb, it will reject the point and write an ffs with the not written point.
2017-10-18 09:55:25|   0.3|  0.0|WARN  |FileGDB Writer: Failed to write Geometry to feature class 'polygons' with geometry type 'esriGeometryPolygon'. Dropping containing feature2017-10-18 09:55:25|   0.3|  0.0|STATS |Storing feature(s) to FME feature store file `D:\tmp\New folder (14)\01_point_to_polygon(2017)_log.ffs'
dbklingdom
  • October 18, 2017
Many Thx, Very helpfull
