fme data types and esri data types
  • February 20, 2017
  • 189 views
arthy
Forum|alt.badge.img+8
Dear all,
I Have a schema mapper transformer that is defined based on an external oracle table
The external table have a column_name destination_attribute_type where I defined the data type of the file to be translated.
Is there any specific reason why "fme_int32" of the oracle table is not converted to "long integer"
For the shape files, the field data type of "fme_int32" yields to a data type "double" with length equal to 11.
Thanks
Best answer by david_r
There was a long discussion on the subject some time ago: https://knowledge.safe.com/questions/32929/short-datatypes-understood-as-long-with-new-shapef.html
Which version of FME are you using? Can you reproduce using the FME 2017 release candidate?
Download: http://www.safe.com/support/support-resources/fme-downloads/beta/
If the problem persists, consider contacting Safe support referencing PR#71956.
  • February 20, 2017
