i have a sevaral text.i need to identify the TBMK12,TBMK13...etc.anyone help.i tried with string searcher but not identify.how to express the value on string searcher
  • September 19, 2019
  • 6 replies
  • 29 views
thirug
string searcher
Best answer by redgeographics
A regex of TBMK[0-9][0-9] should do the trick, assuming it's always TBMK followed by 2 numbers.
Forum|alt.badge.img+62
thirug
14-9-19.dwg
can u check and sent a string searcher transformer expression
14-9-19.dwg
If you want to find all the points with TBMK followed by 2 numbers in the autocad_text_string attribute that regex will work. You do need to expose autocad_text_string first of course.
thirug
thanks but didn't understand the expression.can u please explain.i never used for this expressions
In a Stringsearcher just enter TBMK[0-9][0-9] as the regular expression.
If you go into the Regular expression editor you can get a preview of what it's doing:
So right now it finds all points where in the autocad_text_string attribute the text TBMK followed by 2 numbers occurs (so not TBMK1 because that's only one number). Depending on your source data you may want to add a $ after the end of the regular expression to prevent it from matching on TBMK followed by 3 or more numbers as well.
thirug
  • September 20, 2019
thank u very much
