Extract features that are not labelled
  • October 26, 2016
  • 4 views
jneujens
I am using a shapefile, containing lines, that are eventually printed as PDF document. The lines (streets) are sent into a mapnikrastizers before it is stored as a pdf.
For my current project I would like to be able to identify that lines or labels that are NOT placed by the mapnikrasterizer.
Could anyone come up with a solution for this problem?
Best answer by itay
This depends on the possibility to test the labeling result and the underlaying data schema.
To start with some more information would be helpful.
itay
Forum|alt.badge.img+16
  • October 26, 2016
