From atribute integer count to features
  • August 1, 2017
  • 5 replies
  • 20 views
geospatiallover
Participant
I have an attribute with integer value called number of folders x for a single feature, and I would like to create X number of features. so I can create c number of sub-folders using filecopy.
Best answer by erik_jan
Have a look at the Cloner transformer.
That can make the X copies.
pratap
Forum|alt.badge.img+12
  • August 1, 2017
Have you tried cloner?
erik_jan
Forum|alt.badge.img+26
  • August 1, 2017
geospatiallover
Participant
Thanks to @erik_jan and @pratap. I keep forgetting this transformer even if I have used it a few times. Not the first time I asked in the forum.
danilo_fme
Forum|alt.badge.img+52
  • August 1, 2017
Hi @geospatiallover, let me know if i understand you:
What do you have:
Attributes - number_folders = 4 ( for example )
- Do you want to create number of features ( 4 ) - points / polygons/ or other.
- And you want to create subfolders ?
geospatiallover
Participant
What do you have:
I just needed subfolders. Cloner worked. Thanks!
