Working with Archived Non-Versioned ArcSDE data in a SQLExecuter
  • November 6, 2018
  • 56 views
avansickle
I am trying to use the SQLExecuter to identify records from an archived ArcSDE database where the ID does not exist in another table by utilizing the _matched_records output. My SQL Statement is this:
Select SCRD_ID from gis.STREET_CENTERLINE where SCRD_ID = '@Value(SCRD_ID)'
I know that SCRD_ID: 3745 does not exist in the STREET_CENTERLINE table, but because this data is archived it is coming back with a _matched_record count of 2 instead of 0
Does anyone know how to only read/query the CURRENT data from the ArcSDE database?
Best answer by paulbrandt73
I'm not sure which RDBMS your geodatabase is running on, but I can speak for my experience with MS SQL Server. There should be a couple of columns on your Street_Centerline table, GDB_FROM_DATE and GDB_TO_DATE. These store the date and time period that each particular set of values for the row existed. The default GDB_TO_DATE (in SQL Server at least) is '9999-12-31' for currently active rows. You should be able to add to your where clause to your select like this.
Select SCRD_ID from gis.STREET_CENTERLINE where SCRD_ID = '@Value(SCRD_ID)' AND GDB_TO_DATE = '9999-12-31'
FWIW, in MS SQL Server, I typically also see a view named gis.STREET_CENTERLINE_EVW which has this GDB_TO_DATE filter applied already to return only the active rows, so that may be another option for you.
  • November 7, 2018
avansickle
  • November 7, 2018
Thanks for this info!
We are running on an Oracle RDBMS and by reading in the views did the trick!
One thing was when I added the reader, the views are not included in the list of tables, so I just entered the view name manually gis.STREET_CENTERLINE_EVW and it read the data fine.
Thanks!
