I have a road network (with vectors all in correct direction of travel). I have a number of coordinate pairs (call these the start lat longs) that are found on the network. Each start lat long has an assigned Lenght attribute (ranging from 2m - 300m), What I'm having trouble with is locating an end lat long coordinate pair (on the network) using the Length attribute. I know how to get the length to point and extract end coordinates (using -1 in the transformer), but is there someway in fme to combine the Length to point transformer and add the Length attribute to then be able to extract the end lat longs? Thanking you in advance. Lea
Using a Length attribute and a start x, y on a road network to find the end x, y
