More information for my question. We are not using SQL AG in our system, ideally we will move to this. For now, I have 75 tables in one database that has roughly 300 tables. I only want 75 table in this data copy. We are building this new database as a 'datamart' for reporting and other tools to pull data from this source, as to not effect our Production system. I am testing this today and I am finding the data takes longer than I expect to copy from one server to another. I am testing this using Workbench for now but once I have good results, I'll push the workbench to FME server to schedule this work. For my first test, I am pulling all data and I see the 2500 features are pulled at a time. I am using a static reader not a dynamic reader. For my second test, I will refine the data from the larger tables (over 1 million records) to add in a where condition to limit the number of records we pull. I am attempting to get this to build within 5 minutes. I am looking for Safe's fastest way to pull data from one database to another. I have no transformers in the workbench, simply read and write the data. I am curious what the safe team would do to attempt to build this within a 5 minute time frame ( if it is even possible ). Data is stored within our network and is all located within the same geography. This data has no geometry data types either.
What is the fastest way to move data from SQL database to another SQL database?
