Spell Check attribute values
  • January 23, 2018
  • 141 views
Hi ,
We have 100's of layers and to maintain the data quality we have to perform spell checking on the attribute tables. So my question is is there any way we can check all the attributes string values through FME or is there any spell check transformer. There is always a possibility to have typo or misspell, so cleaning thinngs using FME will be great.
dfresh
  • January 23, 2018
use the python caller. there is a nice module called autocorrect.
make sure you log the ones that are changed, cause depending on input words, you could get some funny ones.
https://github.com/phatpiglet/autocorrect/
  • January 23, 2018
Hi Dfresh,
Can you please show in detail, new to FME. Thank you
  • January 24, 2018
There's already an idea that's been suggested for this functionality, feel free to vote for it here:
https://knowledge.safe.com/idea/45176/string-spell-check-transformer.html
I've also posted some possible starting points (URLs) there.
