Cleaning up FME Server temp files
  • April 18, 2013
  • 5 replies
  • 233 views
nic_ran
Forum|alt.badge.img+16
I have some large processes running on FME Server and they seem to be leaving a lot of files hanging around in the "FME_TEMP" location (Users\\s_fmesrv\\appdata\\local\\temp). Ended up with about 40GB in there in a week, filled up the hard drive, crashed the machine.
Anyone have a good solution for automatically purging this folder? The solutions on FMEpedia seem to be manual processes geared to Workbench on a desktop...
Forum|alt.badge.img+4
  • April 18, 2013
You could potentially set up a FME Server script to perform this! In FME Server 2012+ there is the Utilities that perform similar functionality, so perhaps open one of them and customise it?
I'd personally just create a batch script that browses that directory and deletes things over a specific date and then schedule the batch script.
You could do it programmatically in Python, .NET, Java, etc as well.
Thus depends on what your preference is.
nic_ran
  • April 22, 2013
Thanks, I'll look at customising the FME Server Utilities workflows.
mark2atsafe
Forum|alt.badge.img+59
Hi Nic,
I'm not sure if it's the same issue, but I just saw an update to 2013-SP2 that might solve this. The problem was that FME wasn't deleting temporary files created during publishing a workspace from Workbench. It was essentially a permissions thing and this is now fixed.
Build 13472:
Fixed cleanup of temporary files stored during publication from Workbench (PR#44767)
That might be a different issue - you say your's are created during a translation - but it sure wouldn't help. In our case we found a temp folder on the FME store had - like you - 40gb of unnecessary files.
Hope this is of use.
Mark
Mark Ireland
Product Evangelist
Safe Software Inc.
nic_ran
  • May 9, 2013
Thanks Mark. I still haven't got around to installing Server 2013, so hopefully SP2 will be officially released by the time I get to it!
runneals
Forum|alt.badge.img+29
  • December 28, 2018
This issue still seems to be occurring in 2018. Will be reporting it.
