FME 2017 breaks down adding an existing Feature Type to a new excel writer
I've added a new Excel-writer (it happened also with the existing one). Now I choose the Excel-writer on the Feature type-Parameters-Panel and FME breaks down.
Is this bug already fixed in a newer Version of FME2017? I can't use FME 2018, because we work with FMEServer 2017.
Thanks, Frauke
Best answer by frauke
Solved! After adding a Feature Type I was able to add the writer to other Feature types.
lars_de_vries
Forum|alt.badge.img+10
Could you specify which version of FME you are using?
Before installing a newer version, you can always try to repair your current version if you suspect something is wrong.
  • July 4, 2018
