count
  • May 25, 2018
  • 6 replies
  • 43 views
I need to add an attribute with a running counter to each row in a CSV-file. However, by using @Count() or i.e -4400+@Value(L_SAG_PK) or other similar attribute values, it seems to stop working when the resulting value exeeds 127. How do I generate bigger numeric values.
erik_jan
Forum|alt.badge.img+26
  • May 25, 2018
Have you tried the Counter transformer?
gio
Forum|alt.badge.img+15
  • May 25, 2018
To a existing csv?
You can of course simply expose the "csv_line_number" attribute...
erik_jan
  • May 25, 2018
To a existing csv?
Only if CSV is also the source of the data.
The Counter tranformer gives the same result. Counting fine until 127. After that no resulting value at all.
Found the solution. The resulting attribute was defined as an int8 type, which cannot exeed 127.
