counting exceptions
  • January 30, 2014
  • 14 views
HI,
I need help with try and exceptions.  I have a python script in pythoncaller that with try and except, after running the workbench I will like to count the exceptions  and then get an email that there were exceptions.  What is the best way to o about this.  thanks
'Kemi
  • January 30, 2014
If you defined a global variable, it can be accessed in Shutdown Pytoh Script.
# Example: PythonCaller script
import fmeobjects
# Define a global variable.
g_errorCount = 0
class FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self, feature):
        try:
            # Do something.
        except:
            # When an error occurred, increase error count.
            global g_errorCount
            g_errorCount += 1
    def close(self):
        pass
Takashi
  • January 31, 2014
here's an example using a class instance variable rather than a global variable.
Example:
import fmeobjects
    def __init__(self):
        self.exception_count = 0
        try:
            # Do something.
        except:
            # When an error occurrs, increase error count
            self.exception_count += 1
    def close(self):
        if self.exception_count > 0:
            # Send a mail here...
David
  • January 31, 2014
Thanks guys.  The class instance variable works bette
'Kemi
