I have an AutoCAD text & leader (mleader AutoCAD object) that are on one layer and a structure they describe that is on another layer. The structure is an autocad block, which FME reads as a point located at the block insertion point. The the leader line always connects to it's strucutre's block insertion point. The text is contained in a box that connects to the leader line always in the same pattern. I want to create a workbench that will determine which text/leader objects go with which structure. So it seems like a SpatialFilter transformer set to check if the leader layer touches the block layer should be able to capture this relationship. When I try this nothing passes the filter though, why could this be?
