Best Answer
Can FME convert MrSID to ECW?
  • September 11, 2014
  • 34 views
Is there a way with FME to convert a MrSID image to ECW? Or am I better off to use Geoexpress?
Best answer by david_r
I've never tested this particular translation myself, but FME can read MrSID files and write ECW files, so in theory you should be all set.
David
  • September 12, 2014
David
