SOLVED - I found the error
Hello!
I've been working on a script that has 56 columns (client needs all the fields of information), and now I need to write it using an Esri File Geodatabase writer. I have double- and triplechecked whether there is an invalid character (since gdbs are quite strict with field names) or a duplicate of one of the fields, but I cannot find it. Is there a tool in FME that let's you identify a duplicate of a whole column in the attribute table? Or a duplicate field name? Or does anyone know if there is another common solution to this error?
This is the error code:
ERROR |An error occurred while attempting to create the feature class 'Test'. The error number from ArcObjects is: '-2147220649'. The error message from ArcObjects is: {Cannot create a table with a duplicate column. [Test]}
I am using FME form 2024.1.
Thank you in advance!
