line split as equal parts or distance
  • November 24, 2015
  • 5 replies
  • 546 views
I have road data and trying split line as equal parts or distance.Is there any way for do this?
Best answer by geosander
I think you need the IterativeSnipper_2013, because then you can split it in equal parts of length x. It's basically the Snipper (that @david_r mentioned) applied over and over again.
[edit]
There's also the LineDivider by @takashi, which probably is more efficient.
[/edit]
  • November 24, 2015
Hi
Have you looked at the Snipper?
David
geosander
Forum|alt.badge.img+7
  • November 24, 2015
[edit]
[/edit]
  • November 24, 2015
[edit]
[/edit]
Thank you for your solution.. I used LineDivider.. it worked
mark2atsafe
Forum|alt.badge.img+59
  • November 24, 2015
That's an awesome typo - missing the space between "distance." and "Is" creates a URL that is really interesting to visit!
  • October 10, 2016
Thank you, This worked great for me too. I think it's important to point out that it operates with the distance unit default to the coordinate system of the data, so it is usually best to re-project the data into a system that is meter based, if you want to use those units.
