Calling pl/sql procedures (Oracle)
a) A question similar to the "PostgreSQL Scirpt (.SQL)" one: is there a way of calling Oracle PL/SQL procedures inside a FMW workflow? b) How can I call a DB procedure after the writer is completed, as a post-process item in the FMW workflow? For example, recreating the indexes after writing data.
