Dynamic Paramater Choices at runtime
  • May 17, 2013
  • 21 views
Has anyone been able to link (not import) via SQL a choice/alias list to a published parameter to dynamically update the list based on the linked table at runtime.  I.e. the goal is not have to continually import / update choices each time the workbench is executed.
  • May 17, 2013
I also wish it were possible, but unfortunately, it seems that we can change the definition (including choice / alias list) of a Published Parameter only when creating or modifying the workspace. I don't think it's possible to update those dynamically at runtime.
Takashi
nic_ran
Forum|alt.badge.img+16
  • May 19, 2013
I think the only way to do this is to have 2 workspaces,  the first reads the parameter values and passes them to the second at run time.
  • May 20, 2013
Hi Jryan,
If you are looking for how to select an item from the choice list for a published parameter at runtime, as Nic mentioned, you can create 2 workspaces to do that. I felt that you raised a question about how to update items of the list dynamically.
Takashi
