HTTPCaller POST /Authenticate
  • November 22, 2024
  • 7 replies
  • 81 views
elmido13
Forum|alt.badge.img+4
I have successfully POST Authenticate using postman. But have no luck using HTTPCaller? Any idea please?
Best answer by nielsgerrits
Ah sorry, because this is a POST, you need to move the parameters from the headers to the body.
In Upload Body you need
emailAdress=<emailadress>&password=<password>
nielsgerrits
Forum|alt.badge.img+64
What is the error, issue?
Can you printscreen the HTTPCaller’s screen?
elmido13
  • November 22, 2024
Using HTTP Caller
elmido13
  • November 22, 2024
FME Error
nielsgerrits
Content Type is set to text. Please try and switch that to
URL Encoded (application/x-www-form-urlencoded)
elmido13
  • November 22, 2024
@nielsgerrits Thank you for your response.
Still getting this error below
{"message":"","error":{"fields":{"body.emailAddress":{"message":"'emailAddress' is required"},"body.password":{"message":"'password' is required"}},"status":400,"name":"ValidateError","x-request-id":"kcgXSuAoin2FBs4hVrioNOfk48s5crl0s6IIb-SDMZjCsKZXWhBawg=="}}
nielsgerrits
  • November 22, 2024
elmido13
  • November 22, 2024
@nielsgerrits  Works Perfectly. Thank you for your help
