How can I pull Google BigQuery Data in FME
  • November 21, 2024
  • 111 views
vishnuiam
I want to pull Google BigQuery data in FME and write as shapefile. Can somebody help me on how to do that?
evieatsafe
  • November 22, 2024
Hi ​@vishnuiam thanks for your question. Have you checked out these tutorials?
Let us know if these work for you and if you have any further questions.
vishnuiam
  • November 24, 2024
Hello Evie,
Thanks for the reply. I’ve went through the URLs. I’m struck in connecting GoogleBigQuery in FME using Service Account Key file.
My requirement is to pull data from Google BigQuery tables. I’ve been trying with GoogleBigQueryConnector transformer. And I configured for Service Account Key File with system environment variable.  Nothing worked out for me.
After selecting source account and project ID field is not populated automatically.
vishnuiam
  • November 26, 2024
I finally found the way to pull data from Google BigQuery table using creator transformer with GoogleBigQueryConnector.
And I’m attaching the below post from FME community for public reference. These information not documented along with GoogleBigQueryConnector page.
