Translation was SUCCESSFUL but it gives these errors
  • October 2, 2024
  • 78 views
gjaguilar
After deleting some files using the os.remove instruction within a PythonCaller the translation ends successfully but it gives these errors
Worker 215652 > Failed to apply the constraints feature to the reader
Worker 215652 > Failed to read features from dataset 'C:/Users/LOCA1A~1/Temp/225/wb-cache-CLMS_Download_20240607_DESKTOP_2-igKtLc/LEGACY_DuplicateFilter_2 2 194 fo 0 UNIQUE  2  7b50d2c16b579db61a32ffc86b48776319f4311b.ffs' using the 'FFS' reader
I have searched the web for the origin of the error but I can't find anything that makes sense
I would greatly appreciate any help
Best answer by gjaguilar
HI everyone
Although I did not find documentation about the error, I tried moving the PythonCaller that is deleted just before the process ends and it worked, it seems that some other transformer in the process was trying to read it, the error is not at all clear
Thanks to all
gjaguilar
  • October 2, 2024
HI everyone
Thanks to all
