DateTimeConverter and NULL values
  • August 29, 2024
  • 172 views
vki
Forum|alt.badge.img+7
I want to convert the format of a date-attribute from %Y%m%d to %Y-%m-%d by using the DateTimeConverter. This works fine, as long as there are no Null-values. As soon as there is just one Null-value, all other values are set to Null as well (even though the option “Passthrough Nulls, Empties or Missing” is set to Yes).
I tried to filter out the features with the Null-values, convert just the features with values and merge all features after the DateTimeConverter again, but here too, all attributes are set to Null.
If I set the Null-values to a dummy-date, then it works. But I don't want dummy-dates, but Null-values, so how do I do this?
Thanks in advance, Vera
Best answer by hkingsbury
What version of FME are you using? I just tried in 2022.2, 2023.1 and 2024.1 and it worked as expected
bwn
Forum|alt.badge.img+26
  • August 30, 2024
Perhaps a sample/screenshots of the workspace and Transformer configurations?
DatetimeConverter will only Null for the selected Attributes where they have an invalid format against the Date/Time pattern being tested.   So Nulling all Attributes should only happen if All Attributes have been accidentally selected to convert rather than selecting  just the Attribute(s) wishing to convert.
vki
  • August 30, 2024
Here are some screenshots. Obviously, in the transformer the type of the data changes from date to buffer, but this happens not just for the Null-values, but the dummy-data as well.
hkingsbury
Forum|alt.badge.img+67
  • September 2, 2024
vki
  • September 4, 2024
I have found the error. It has always worked correctly. I had looked at the results with the ‘Visual-Preview’-Tab by sorting the corresponding column ascending and descending. That way I only saw zero-Null-values (the majority are Null-values) and I missed the fields with the correct date formats, even though they always would have been there…
