google sheet reader
  • August 23, 2024
  • 50 views
farzaneh.ahmadi
Forum|alt.badge.img+5
Hello everyone,
I am reading a google sheet with Google Sheets v4. The reader runs but it does not read some of the columns. I do not get any errors. how is that possible? I thought maybe because those columns cells are empty they can be read and then I added values in some cells but that was not the case. it still does not read them. in the workbench when I view the source data they are there in the sheet.
Forum|alt.badge.img+62
That’s really odd. If you can view the source data in Workbench it means the connection to the sheet is good and FME understands the data.
Can you try “Rerun entire workspace” first (sometimes, if you make changes to a reader, caches can act a little bit weird) and if that doesn’t help, removing the reader and adding it again?
farzaneh.ahmadi
Thanks @redgeographics. I deleted it several times and added it again but still I get the same result. This is the first step and I just added the google sheet v4 reader to my workbench.
