How to reassign address ranges to segments after breaking the segment
  • August 21, 2024
  • 74 views
ravibansal
Forum|alt.badge.img+4
I have streets with LEFT and RIGHT address ranges assigned. In some cases, I need to break the segment into 2 or more segments (for example, when a railway track is crossing the street).
How do I re-calculate the NEW address ranges for the NEWly created segments? For example, as shown in the image, parent segment has address ranges of 0-100 and 1-99. After braking it up into 2 segments, I am expecting to calculate and assign address ranges of 0-28, 1-29 and 30-100, 31-99 to the child segments.
Which transformers can I use to calculate the address ranges for the new segments?
jeroenpeters
Forum|alt.badge.img+5
  • August 28, 2024
Maybe you could fiddle a bit with measures and the measuregenerator? Good luck 😎
