Error "The table name or field names may be too long or invalid for the server"
scarecrow
Forum|alt.badge.img+4
Hello,
I’m trying to read specific feature classes from an SDE database using a user parameter within a feature reader.
I’ve not had a problem with this previously so not sure if it’s a bug (I’m using FME 2023.1.2.0 (20231110 - Build 23641 - WIN64)
The issue I’m having is:
When selecting feature classes manually in the ‘Feature types to read’ section of the Feature Reader window I can select as many as I want and they’ll all read fine.
When using the user parameter (please see settings in screenshot below):
Selecting one dataset reads fine
Selecting 2 or more feature classes I get the error “Error creating feature dataset 'feature class a feature class b'. The table name or field names may be too long or invalid for the server”
Thanks for you time
Best answer by scarecrow
 @crystalatsafe thanks for your reply.
Sorry I can’t share the workbench but it is just what is shown in the screenshot. A creator linked to a SDE feature reader, with all default settings. As you say I think this is an issue with the version I’m running.
For now my workaround is to use a parameter fetcher to get the inputs set by the user, send it to an attribute splitter to separate the feature classes and then use a list exploder to create an attribute that feeds the feature reader.
crystalatsafe
Forum|alt.badge.img+18
Hi @scarecrow
It looks like a similar issue was fixed in a newer version of FME (2024.0.1).
If you are able to, please send your workspace over and I can take a look.
Crystal
scarecrow
  • June 14, 2024
crystalatsafe
Hi @scarecrow
I’m glad you were able to find a workaround.
If you do test this is in 2024.0.1 or newer please let us know how it goes.
Crystal
