In ArcGIS Pro a TIN can be created using the “Create TIN” tool. The usage notes of the tool say that it should be avoided to use a geographic coordinate system when creating the TIN, as the Delaunay triangulation might not work correctly when the coordinates are in angular units.
The “TINGenerator” transformer in FME does not provide such a usage note in the documentation. Does this mean that the “TINGenerator” transformer can create a TIN without problems when the input dataset is in a geographic coordinate system or is it also recommended here to reproject the input data to a projected coordinate system first?
