BUFFER 3D object without Rounding OFF corners ?
  • April 29, 2024
  • 61 views
vimva679
Forum|alt.badge.img+9
I would like to create 5 cm buffer around 3 Cube without having rounded corners or edges.
Exactly the same as its original with 5cm buffer ?
thank you in advance
hkingsbury
Forum|alt.badge.img+67
  • April 29, 2024
Would the Scaler be a possible solution? It does work on a multiplier, so you wont be able to specifically set it to 5cm but if you know the current dimension of the cube you could work out what the scale needs to be to get it very close to 5cm
