- Within FME I have a PolylineZM shapefile with about ~12,000 different routes on it.
- These routes are wells, they straight down into the ground and then go horizontally.
- From within ARCGIS I can see that the PolylineZM shapefile coordinates already have Z values as well as measures associated with it.
- In that polyline shapefile I have an attribute column with called depth that has a distance value which represents the 3D distance along the line.
- I am wanting in FME to create a point shapefile that overlays the line at that given depth.
Does anybody have an approach that they think would work to accomplish this?
Thanks
