problem of date with testfilter and attributcreator
  • April 3, 2024
  • 87 views
nico42
Participant
Hello everybody.
I'm stuck I think over a trifle.
I have a dataset with dates like "1970".
I want to create a column allowing me to have date classes in it (for example [1970-1980[ ).
It seems to me that I need to go through a testfilter and a creatorattribute but what I do inside doesn't work.
Could someone give me a hand on the operation so that I understand how it works?
Thanking you very much in advance
nielsgerrits
Forum|alt.badge.img+64
I think you are looking for the AttributeRangeMapper.
becchr
Forum|alt.badge.img+33
  • April 3, 2024
if your aim is to get something like this:
you could do it in one step instead of using testfilters and attributecreators with several conditions, which is harder to setup and maintain in my opinion.
To get the ‘dateclass’ column based on the column ‘_year’, I used this syntax in the text editor of an attributecreator:
@Evaluate(@floor(@Value(_year)/10,0)*10)-@Evaluate(@floor(@Value(_year)/10,0)*10+10)
but there are many other ways to achieve this...
nico42
Participant
  • Participant
  • April 5, 2024
tha,ks a lot for your returns
